Good Evening everyone,
I am new here and I have a question. I have been running a 1957 union pacific set since I was a toddler. The transformer is a lionel 1033. This year as a set it up around the tree, I ran into something weird. I run it off posts U and A. It would not run, so I took it to my bench and here is what i found.
If I put my multi-meter on the posts I get good solid readings 0 to 16 volts. if I connected wires to the posts and screwed them down and put the meter on the wires, the voltage went to less than 1 volt, i made a new wire and got the same result. now the weird part..if i wrap the wire to the post i get 0 - 16 volts on the wire, if i screw the posts down it goes to less than 1 again. if i remove the post nuts it goes back to 0 - 16...
the post nuts are lionel OEM and have worked for years. it seems the only way to fix the problem is to ware the wire vs use the post nuts..
i am baffled...any thoughts or advice is most welcome.
