Greetings all,
HELP - I guess in Southern California Home Depot and Lowe's does not sell full 4'x8' sheets of extruded (pink or blue) foam. Home Depot only sells 2'x2' by 1 inch extruded (pink) foam. I'm wanting to build a small 4'x3' N Scale layout on top of a 2" think foam.
I purchased several 2'x2' foam boards. I cut, stacked and glued them together to create the 4'x3' by 2 inch foam base that was glued into a piece of 4x3' piece of hard board at the same time. However, all the foam boards I bought were slightly warped. I stacked another large piece of hard board on top and place several weights on top to see if the warpping would flatten out during the drying process of the glue. That did not work
When the glue dried and I removed the loose piece of hard board and the weights ...... No Luck ..... the warped pieces returned to their original shapes.
I went to several Home Depots to check the stock and all these types of pieces are warped just enough to make them a bad option for me. Of course both Home Depot and Lowe's have full 4'x8' sheets of the white Polystyrene..... But I've read that this does not work if I want to carve into the foam to create land forms, rivers, etc.
I'm looking for any suggestions. Any other types of foam you may have used with any success?
