1 - 4 of 4 Posts
I just bought three identical coal hoppers on e-bay. I will need to change their numbers (they also are the same). How will I remove the old numbers, considering they are packd very close underneath the L&N logo, which I don't want to damage?
You can try to soften the number you want to remove with airbrush cleaner......at least that’s what I use.....maybe test first on a spot that’s not visible, to make sure it won’t dissolve the paint right down to the plastic.....let it soak on the number to be removed for a minute, then gently rub, or gently scrap (I use a curved exacto blade) the number.......the paint should crumble or curdle off.....it might take a couple of soakings, as the paint layer is removed......when the number is gone, carefully wipe dry, then you are ready to re-decal a new number.....
Migbait;
First put a piece of 3M Scotch brand blue painter's tape over the L& N logo that you want to save. Press it down tightly on the side closest to the car number you want to remove. Next, you might try a pencil eraser. Use a white one of those replacement erasers that go over the original eraser when it wears down. Wet the eraser with a bit of 70% alcohol. As Old Hobo suggested, try this on an old car first, to see how it works.
Good Luck & Have Fun ;
Traction Fan 🙂
Migbait;
Traction Fan 🙂
I will do as you guys suggest. Thanks a bunch.
1 - 4 of 4 Posts
