1 - 4 of 4 Posts
Hello all
In previous posts I mentioned that I had a small toy Lionel engine that was not working.
I took it apart by removing three rivits that held the housing together
There is a small 1/2 inch long 5/16 inch in diameter piece of plastic that connects the motor to the gears. this piece of plastic has a small round hold in the end that connects to the small round motor shaft (must have been glued )
in the other end is a small rectangular hole that the first gear fits into.
at first the gears would not turn and I noticed that the grease was al hard, and the piece of plastic was loose and split where it connects to the motor, thus no movement.
I will have to clean up grease and regrease the gears.
What kind of grease should I use??
I will post pictures over the weekend, hopefully
That's all for now
Aaron
· Premium Member
Aaron,
Lots of guys use white lithium grease. You can buy a small tube of Lionel-brand grease from your local hobby shop or online suppliers. That said, I don't think the specific type of grease is super-critical for your gear casing ... do you have any grease on hand?
You might first clean out all of the old grease and then try to super-glue the plastic piece back on to the motor shaft first (while everything is clean / greaseless). Then after that drys, go ahead and grease.
A, I think any lightweight grease will do. I normally use white lithium, but I think the critical issue is fresh, clean grease instead of no grease or old, hardened grease. I still have some teflon trailer-hitch grease in one engine that I used when I couldn't find the lithium, one night. *L* The locomotive was happy with it!
1 - 4 of 4 Posts
