1 - 4 of 4 Posts
i got all the track and DC i need now i want a scenery do i use that staple the cardboard strips or insulation foam which is cheaper which is more messy (i like getting in messes when it comes to my RR) what base should i use for mountains TELL ME PLEASE :D
:confused:
:cool:
:p
Pink foam is a bit messy in that you get lots of little pink dust when carving / sanding it. However, it all vacuums up quite easily with a shop vac, and there's really no sticky goo, as with plaster layup. Wear a dust mask, and have the shop vac handy, and you should be fine.
Personally, I like the foam in that it paints quite well using standard latex / acrylic paints.
It's available in 1/2", 1", and 2" thick sheets, so you can mix/match these to achieve you intended ground slopes, grade changes, tunnel interior heights, etc.
Good luck,
1 - 4 of 4 Posts
