Old HO engine's won't run
1 reading
3K views 7 replies 5 participants last post by  MidwestMikeGT
#1 ·
What is there I can do for my older train engines that won't run down the tack? The light comes on but won't roll & when I put another one on the track you can tell it labors from the draw on the one that doesn't roll/run but the light is on? Any suggestions? Thank you for any & all replies guys!!
#7 ·
The wheels pick up power so they need to be cleaned well. Isopropyl alcohol on a Qtip usually works. Gears can also be cleaned this way and lightly oiled with a plastic friendly oil such as Labelles. Make sure there’s no debris stuck between the gears and the case.
We have a few members who run a lot of Tyco.
They may have some specific suggestions for these. Also, clean your track. Do not use steel wool for any of this.
