1 - 18 of 18 Posts
In case of a screwup how fast can you exit the rail if needed? :oops:
Do you have to find a crossing to get off the rail?
Discussion Starter · #6 ·
A crossing helps, but in the event of a “screwup” out the door is fastest escape route, my rail gear is hydraulic and I have buttons inside so I can pull my wheels up pretty quick
OK, the door ha ha ha.
Yes I know you can raise the wheels but then you would have to jump the rail somehow with the truck.
That is easier said then done without blowing the tires.
Do you ever think of that when rolling down the rail? A train coming at you? :) I would. lol
It would be real scary to see a speeding train bearing down on you.
If one is coming up behind you it might be better, you could either outrun it or end up being pushed by it.
How fast can you roll down the rail? Not by a set company standard. How fast can you roll before you are on the edge?
Discussion Starter · #8 ·
The limit for my truck is 45, I usually run between 25-30, I don’t worry about a train coming at me, when I run the 70 mph double track and I have one going past on the adjacent track at speed the thought creeps in my head once in awhile but it don’t faze me, trains flying by me arms length away doesn’t bother me one bit
I would need to pack an extra pair of underwear if I had your job, LOL!
1 - 18 of 18 Posts
