So I am building my layout, not going for a scale layout but more of a Tribute to the trains of the days. I want to use old plasticville buildings and add some features like trees and hills etc.
I want to know if you think I'm moving in the right direction or if I should consider different track. I started with Fastrack on the base level and was planning to use o27 I got in a marx set for the upper level. I just found another set which had a bunch of track and several o27 switches. So now I think I want to go with o27 for the whole layout. Is that a practical choice? How easy is it to find new track in larger radius than o27? I used a mix of o27 and o34 marx curves for the Mock up of the upper level.
Using the Marx track I can add some turnouts and loading docks to the layout vs the fastrack. Another reason I'm asking is I can only find used marx track for the larger turns. Did lionel make larger turns in o27 and am I making a mistake using old track and switches?
Sent from my SM-G892A using Tapatalk
