About 3 years ago I picked up a nice Atlas S2 Gold Edition with DCC and ESU Lok Sound. It has sat in its box ever since until today. For grins and chuckles I picked up some Kato UniTrack and Peco Code 55 flex track with one medium sized turnout for each type of track. The Peco turnout is #6 Unifrog RH. The Kato Unitrack is also their #6 which is frog powered and not adjustable like their #4 yard switches..
Trying the Peco track and turnout first I experienced some jerkyness with the S2 especially through the turnout. Powering the frog made things better going through the turnout but the jerkiness persisted on the regular track. I attributed this to the lousy rail splicers that come with the Peco track that need soldering to work well. So, next the Kato track. Powered the section of track at both ends so both sides of the turnout have power when switched. Turns out the Alco struggles a bit sometimes but not always jerking a few times going through the Kato turnout. Sometimes the sound cuts out, sometimes not.
So, for grins and chuckles I decided to measure the track and the wheels of the Alco. The Peco track measures 9.01 mm and the Kato around 9.03 or so. Not bad. Now it gets interesting. Outside flange to outside flange of the Alco wheels measure 8.50 mm. When the Alco is on the tracks you can visibly see and feel a side to side slop if you will when moving the loco.
So, finally to my question. Apologies for the long post. Is this much difference normal? Could this be causing my issues? I have no other locos but the one to try.
Thank you in advance for any help.
