Does this help?Hey all,
Does anyone know where I can get a set of instructions for the Sandy Andy automatic ore loader?
I've checked some of the parts websites and there is nothing for accessories
Thanks,
Cheers, Ian
Thanks big ed, you da man
That is exactly what I needed:thumbsup:
Where did you find it?
Cheers, Ian
Cool, thanks:thumbsup:
What parts do you need, and where have you looked?
The instructions say....I think they said,cog,
I'm missing the handle that goes on the back that controls the weight, and the chute that directs the coal into the hopper is broken.
The chute I might be able to fix, but not sure about the handle
My granddaughter is only 6, so no coal involved:laugh:
Depends. I ended up with one ore and one gravel unit with the only difference being the color. The stuff is smaller than regular Lionel gravel so the chute lever will not jame open.....which it still does. The level on the back is essentially a flapper with a slot in the middle to let the string move up and down and stops the weight when moved.The instructions say....I think they said,
ONLY USE LIONEL GRAVEL with it. Maybe it said ore?
I will check.
Edit,
Yes it says Gravel. and only Lionel gravel will work.
So it is a gravel loader/unloader.
Are you missing the weight stop handle?
Maybe you can make one?
Thanks for clarifying that.Depends. I ended up with one ore and one gravel unit with the only difference being the color. The stuff is smaller than regular Lionel gravel so the chute lever will not jame open.....which it still does. The level on the back is essentially a flapper with a slot in the middle to let the string move up and down and stops the weight when moved.
Yes, you could make one out of brass and it should work fine.Thanks for clarifying that.
I never even heard of one before this thread.
I would think the you can make one of those in brass?
Doesn't look like there is much to it, just bend a brass rod to shape and make up and attach the flapper part? Heck it doesn't even have to be brass.
If I am looking at the same thing your talking about?![]()
