Sometimes it’s a matter of timing...with some luck thrown in for good measure...
Here is a recent photo and in my opinion, including the smoke certainly can add an additonal element of action and realism...
My best smoking engine is MTH RailKing ProtoSound 1 engine. I rarely run it anymore because it is conventional and I only run command controlled engines on my Christmas Layout each year.
This is one of my "all time favorite" photos from my Christmas Layout in 2003 with engine coming out of a tunnel...
The best smoke I ever saw was when the smoke regulator shorted on a Legacy 10-wheeler, it came out of a tunnel and looked like it was on fire!
This is a clip from one of my upgrades, I added fan driven smoke to the Hogwart's Locomotive. For some reason, the smoke seems to show up better in video than stills.
I tested the 16 ohm resistor on the standard R2LC, and it results in the smoke triac running right at it's destruction limit, over 100C! Too hot for me, and if it's close to the plastic shell, I can easily see it deforming it, even if it doesn't croak.
Smoke shows up best in front of a dark background. Notice for the trailing unit here, you can’t see the smoke just above the exhaust since the background is gray, but a little higher up, the smoke is quite obvious.
All of my best smokers are MTH. My MTH tinplate steamers will absolutely smoke out the room. I don't own any non-tinplate MTH steam engines so maybe they will too? My Lionel engines (both diesel & steam) smoke okay but not profusely.
Still building so nothing finished but Crabcake just asked for smoke. We have two engines that the kids love; slow down and the smoke rings are even better than this. They don’t slow down.
I have never caught "Old Reliable" (first run Legacy FEF-3) doing smoke rings although she does at slow speeds. This screensaver is of a single puff and I am particularly proud of it because it's from after the AC regulator had to be replaced as well as the smoke unit batting:
Normal service was resumed. That's important because I will never forget when I first put power to this engine on the track and the smoke started to billow out. I could not believe what I was seeing.
The smoke regulator shorting is one of the more spectacular smoke events possible, it gives you some outstanding smoke, but only for 20-30 seconds! The only long term effect is you seem to smell the charred circuit board odor for years! hwell:
I have a N&W J in for repair, and it blows perfect smoke rings at almost every chuff, it's a cool effect. It's all about the size of the stack opening and the velocity of the smoke exiting the stack.
Related Threads
Model Train Forum
883.8K posts
32.2K members
Since 2006
