1 - 12 of 12 Posts
Just figured out the easier way to add photos. I model the Burlington Northern merger, but every once in a while change out the rolling stock to modern day intermodal traffic. Typically wouldn’t have 53 foot containers in the yard....
E679A80E-E224-421E-9963-8BED678A1898_1546230683049.jpg 9D6628D5-93E9-42EB-BECC-34B7CFFD20BF_1546230659113.jpg 3109D9D2-6F1D-463B-84AD-D96916B4F7C4_1546230643046.jpg
A fine looking layout. Is this a point-to-point, or do I see an "escape" track at
one end? Love that green bridge- very captivating. What is the black box on
the side of the layout?
Thanks, this a continuous run shelf layout. Photos tell the story. I take that the black box might be the RV flip beverage holder. You can get thirsty running a class 1 railway.. .cheers
Built some furnace filter trees.
Bamboo skewers, and a furnace filter. One filter can build a big forest worth of trees
I use a light brown marker to colour the trucks (2 trucks from 1 skewer
I cut the filter material in a triangular shape, and feed the skew through. I use no adhesive as it sits snug on the skew. I will shape the filter till I get a shape I like.
Extra material left over from trimming is made into bushes, I mount the bushes with T pins, ready to paint.
Bushes painted, and flocked with weeds, and green blend grass from woodland scenics.
Tree spray painted, ready for flocking. Trees planted (top photo)and some bushes added as well. Start to finish for 8 trees/bushes is 15 minutes
Nice technique, I like it. I thought for a second that you were making "blue" spruce, but then you painted them! LOL
Great idea
This is a great concept and seems easy to do. I will definitely be trying this out. Thanks for sharing. 👍
Discussion Starter #10
I held the trees at the trunk, with a straw around the base, to protect from overspray.
The colour was called Expresso, satin finish, and the filter material can be brought at Home Depot, etc.
Very economical to make, and the more time you spend “teasing” out the filter material the better it looks.
If I make a tree, and am dissatisfied with it, I make bushes out of it..cheers
1 - 12 of 12 Posts
