I have a question for all you electrical guru's. I have a 2.4ghz pin-hole camera that I am mounting in a Model Power Alco FA 2 Like this one:
http://www.bing.com/images/search?q=scale+alco+f3&FORM=HDRSC2&&id=7E75231950AC96A7B1D7368FE93D8E59F20C7F2D&selectedIndex=26#view=detail&id=7E75231950AC96A7B1D7368FE93D8E59F20C7F2D&selectedIndex=0
I stripped the motor and the drive gears out of this loco to create space, but I kept the power pick-ups to power the video camera.
The pin-hole camera fits very well, I removed the lower forward light reamed the hole out just a tad, Got very good test pictures!
My question is picking up power from the track. The camera requires 5vdc so I have a 3 pronged voltage regulator to step the track down from 12vdc-13.8vdc down to 5vdc.
Here is my question: what happens if I run it on a layout that has the polarity reversed? Or a DC layout and the polarity is switched to reverse the locomotive direction?
If it were a motor or a fan it would run backwards. I am not sure how to remedy this situation.
Other than that issue she works great!
Thanks for your help!
J.C.
J.C.
