Let us start with a picture taken from your digital camera on your computer.
and you want to post it in your gallery. The forum needs small pictues to run fast. So your pictue needs to be reduced before upload. So go to programs/accessories/paint and open your photo. You want to reduce the pic to 600 pixels or less across. ( avatar is less than 80)Under tools use skew and change the 100's. depending on your size depends on the reduction. I reduce to 18 by 18. Experiment and use edit undo to try again. Even add text or draw colors. then 'save as' a jpeg.
Next upload to your gallery and follow directions. You may have to start your gallery first. I can't remember. In your gallery make sure you do not upload into someone elses gallery. You can block this from happening in your gallery options.Any comments?
