It starts with rust. The best way is to remove the wheels and wire brush them out.
But the tabs breaks
at the orange arrows. It's not the end of the truck. Just fix it. First you set the axle back in and use super glue on the joint.
This hold everthing so you can support the back with two part epoxy.
It holds but may not be as strong as the original joint but it works for now.
I may tag it with some red paint to identify it as a repaired truck.
But the tabs breaks
