The tender trucks usually pickup current. If they are turned the wrong way, they will produce a dead short when attacked to the engine.Thanks, Late Starter for the reply. Don't know why turning tender truck around would work as both look exactly the same. Forgive my ignorance - HO tech is not my strong point. To do that would do what? Thanks...
callmeIshmael;View attachment 513506
View attachment 513510 Although I've been an O-gauger for years, I'm trying to help my son with his HO layout. We have trouble understanding the hookup from the tender wipers to the loco. Right now, the loco moves okay on its own. as soon as the tender is on the rails, the loco won't work. I've tried different wiring solutions with no luck. Could someone pls. explain how the tender works and why it has a resistor or capacitor inside it? Is it only for the light hookup to the loco? I notice the tender also has a light on rear. No lights work so far. Thanks!
Turn the tender over...... Right now, the loco moves okay on its own. as soon as the tender is on the rails, the loco won't work. I've tried different wiring solutions with no luck. Could someone pls. explain how the tender works and why it has a resistor or capacitor inside it? Is it only for the light hookup to the loco? I notice the tender also has a light on rear. No lights work so far. Thanks!
Tender prob. goes with locomotive and clip was removed from locomotive. Not a big deal, they can be wired together and left together to work fine. Next off, judging from the fact there are 2 wires going to the tender i'm willing to bet the tender picks up positive and negative somehow.It looks to me that the leads of the diode are not insulated and could short to the weight when the top of the tender is put on. Does anyone know for sure if the if the tender trucks need to be set to pick both the A and B side of the track? Or does the the tender only pick up one side and the locomotive the other? It's certainly not clear from the pictures. The Locomotive appears to have had the connector removed or perhaps this tender does not go with the locomotive. Too many possibilities here to figure out!
I have a couple of IHC Command XXV steamers made by Mehano. The tender wheels on those have both the positive and negative pickups. I accidentally reversed a truck on one of those and it was dead as a door nail until I fixed the truck.It looks to me that the leads of the diode are not insulated and could short to the weight when the top of the tender is put on. Does anyone know for sure if the if the tender trucks need to be set to pick both the A and B side of the track? Or does the the tender only pick up one side and the locomotive the other? It's certainly not clear from the pictures. The Locomotive appears to have had the connector removed or perhaps this tender does not go with the locomotive. Too many possibilities here to figure out!
