1 - 9 of 9 Posts
I am creating this thread to keep tabs on nifty products that are suggested for use by our members.
This is for silicone rubber mold making.
Mod Max 40
I can't forget Goo Gone
Or motor oil
I like the Gorilla glue too.
Puts on a strong bond! That is for sure!
The first time I used it I found out how a little drop will do it!
I did not use too much and look how it expanded on the pilings I was making. I used a dremel tool and cleaned them up.
Does all the Gorilla glue expand like the stuff I used?
Then when I glued the pilings to the base.
I use the dremel tool to clean them up a little, but instead of getting rid of all the expanded glue I made them into a little wave action against the pilings with paint.
I love the birds, Ed. You just don't see birds on railroad layouts.
Yes. ALL Gorilla glue expands. But NOT the Super Glue by them.
I see what you did with the waves. Nice to see intelligent people.
I found out the hard way with G.G. also. I was lucky to literally saw most of it away and paint the leftovers to match the building.
WOW! If that evaporust works even half that good, it will be wonderful.
Looks better than Naval Jelly.
I also like Loctite products, particularly the little "squeezy thingy" on the sides of the bottle. Makes it easy to apply the correct amount.
1 - 9 of 9 Posts
