1 - 4 of 4 Posts
Hello,
I have laid out my train using RailModeller for both levels. However, I have two small pieces of track that won't connect and I cannot find the right size. Can someone please help?
Thank you!
Well, the graphic is too small to really see what you're doing, and of course we'd have to know what brand track you're using and where the problem is. Finally, it may be that only someone with the software will be able to diagnose the issue, hard to say without more details.
John is correct; however, another idea might be to upload the file generated by the program so that someone else who uses the program might be able to help you.
Chuck
Thank you
Thank you both for the help. I was able to figure out the track I needed to correct the angle of the curves. :)
1 - 4 of 4 Posts
