1 - 3 of 3 Posts
after bout with bad luck health , starting back up again . tore the old layout down and starting over . old layout using dcc and suitcase connectors for track feeders . checking for power coming off the feeders 2 were dead . going to terminal blocks for running bus and track feeders . ( where do you get and is there a correct size ) . my layout is going to be 4 x 10 with up and over . using 12 awg twisted for bus . any suggestions are appreciated .
mike
You might try these connectors for taking power from a 12v bus make a drop to an LED light. Essentially what your doing with the track. Nice things is you can actually disconnect the feeder to make problem solving easier.
search for wago Luminaire, even amazon has them.
after doing some research , I'm going to use posi taps to do track feeds . I still have a lot of work ( research ) to do for my layout and my table especially the up and over .
mike
1 - 3 of 3 Posts
