Lately, I have been ignoring my LED curiosity. Today I was in Radio Shack, shopping with the family. I mowsied over to the electronic parts and hit paydirt. Tis the Season!
I found surface mounted LED's. I bought 2 white for 2.39.each. Here is one operating on 3 volts.
The orientation has the positive feed to the bottom and negative at the top. Comparable to the bulb LED of the the long lead being positive and the short negative.
Now for the technical. They are low profile not actually a surface mount but ideal for our use. The surface mount I have seen at FRY's on the west coast were prewired to a strip and about half the size of the one shown. They have a 130 degree angle of viewing.They are advertised as high inensity but the picture was distorted by glare. High but not super bright.The last photo I could see the clear case. Operating range is 3.5 to 4 volts DC. These are ready to solder to a common board. They have 4 leads to make it easier to string out. Two leads for power and ground and two for the next one. Two could easily light an O scale car. Ideal to light a scale workshed.So far in my work AC or DC power suppllies have worked. The problem has been on board ligting from the track. A 9 volt battery will work. But the reversing polarity of the rails is tricky and DCC is entirely different. The only sure way to light is with a voltage regulator and bridge rectifier on board. For the moment just sit back and say Cool!
Product number is 276 0024
