I noted that if you move the mouse down to the "Recommended Reading" a question appears that ask how it can be improved. Unfortunately none of the "allowed" responses are "eliminate this garbage", probably because the programmer is very proud of this code and truly want's improve it. But sometimes its best just to get rid of distraction that just causes really old discussions to be inadvertently resurrected. Remove the Recommended reading and make the forum easier to look at! You could add a remove option to the survey and you might get a lot more responses!
