1 - 14 of 14 Posts
Have you tried soaking it in really hot water?
I do not know what kind of decal is required for this to work... How hot were you thinking? I know that I tried removing one of the "oiling" stickers off the base of a prewar Lionel and it was not even budging at 250 degrees in my oven... With newer things though, arn't the decals sort of "burned" into the plastic? I do not know for sure though :dunno:
No and plus I just took an hour th do the decals on the side of the cab.:confused:
Do you have any pics yet? :p
Maybe you can try this? I found it when Googling what Dullcote was :)
I think this was taken out of context and is really about repairing cracked decals, but if it makes them so soft then I would think that it works for removing them :dunno:
If your decals are cracking, give them a really good spraying of Dullcote, then soak them in micro-sol (not water) and wait until you can slide them off the backing. Make sure both sides are thoroughly soaked! Be careful, as the decal is very soft at this point. Then apply normally.
Decal Removing
Are you talking about the original logo from the manufacter? Are you shure it is a decal and not paint? I have found on some brands the painted on markings can be removed with 70% iso alcohol with a stiff brush.
1 - 14 of 14 Posts
