Boom!If the base is E12 candelabra, you can get warm white LED bulbs here. I’ve replaced most of my C9 Christmas bulbs with the larger version and I like them.
https://www.amazon.com/Brightown-Re...ix=c7+led+christmas+light+buls,aps,189&sr=8-5
The ones I liinked are C7s at about half the price of the Emotionlites. I only mentioned the C9s because those are the ones I used for my Christmas lights.If the C9 bulbs are too large, you can go with nightlight LED bulbs.
https://www.amazon.com/Emotionlite-...&sprefix=candelabra+base+night,aps,137&sr=8-7
It's the sticky-back LED strip with the remote.daschnoz, I can tell the difference, did you use red LEDs, or are they the programmable type that you can adjust electrically?
Mr. Toad, in one of you other threads I see Mike suggested a power supply from ebay. As said, it can be as easy or as complicated as you want, so you'll need to tell us exactly what you want so we can make better suggestions. The easiest way is the first ones I linked, the Lemax LED replacement strings. They come in various versions, singles, doubles, 4, 6, maybe more. If you only need 25 lights then you can do that with4-5 strings and be done. A little pale yellow paint and you're done.
ADDED: Or the gel ErnestHouse mentioned... I never tried it, or even heard of it for that matter, but I'll have to check it out.
The easiest approach would be to use a dimmer on the Dept 56's existing bulbs. When you dim an incandescent bulb, it reduces output but also tones down the color from white to yellow.I would like to (with your help) replace the Dept 56 Snow Village White lights used to light the houses - change to a warmer glow and to a LED bulb
What do you suggest
Thanks
MrToad
