Did you ever have any luck finding a suitable frame for your Athearn Bart cars?
Did you bother replacing the dummy frames, so as to get a consistent/more prototypical look?
Looks like I managed to score one, and I'm wondering how much effort/time/Money I will be putting into it. Given the suggestions in this thread, I suspect I will be looking for a full frame replacment withing seconds of it arriving...
Congrats on a good find!
I ended up doing a lot of custom work. For the powered car, I bought an old Athearn GP frame. I then lengthened it and removed the fuel tank in the middle. I cut the frame in half with a Dremel, then used brass stock to lengthen it to where the trucks should be. I added some styrene to the ends to make the total length of the frame the same as the shell. There is very little clearance between the floor of the frame and the top of the shell, so I bought a narrow diesel Athearn repower kit from Northwest Short Line (part # 1163-4). The motor and flywheels fit perfectly, and the motor is very quiet.
Attached are photos of the frame with and without the shell. Please forgive the janky wiring--I took these photos during the testing phase. Also note that since taking the photo of the BART with the shell, I've moved the trucks a little further out toward the ends. When you look at prototypical photos, you'll see that BART's trucks are very close to the ends of the cars.
For the non-powered cars, I lengthened a bunch of 40' Athearn Blue Box boxcar frames (I used 40' versions only because I had a bunch sitting around). I simply cut them in half and added styrene to the middle. These custom frames fit really well and are easy to work with.
To be honest, this project has taken a lot of my time--though mostly because this is my first time doing significant modifications to frames or drive trains. Nonetheless, it's been fun and a great learning experience.
Good luck! Please let me know what you end up doing.
Best,
Doug
