1 - 20 of 21 Posts
Had 2 tables sitting in garage for a while so i decided to use them as a rough layout for my hawthorne village coca cola express.I have a bridge tressel set and more track coming.I also decided to put a quick shot of the lionel train cars which i got from my grandmother in 1993.
I will be picking up a 4x8 board for the train but am having a hard time using the anyrail program to see what kind of layout i wanna do.I have the 18piece truseel bridge set coming tomorrow and soon more track also.
Discussion Starter · #2 ·
Got my 4x8 plywood board this morning and my 18 piece ez-track graduated pier set.I wanna do a simple setup and will have a track cleaning car parked away on it's own short track with left hand switch track.This will be my first attempt at making a layout.
· Premium Member
Dicey support on that second (smaller) table, huh? Are you planning on building a proper frame to support the plywood ... 2x4's, etc.? Legs? Hate to see you go too far with your layout, only to have gravity take over on that floating table.
Good luck ... ask questions as you proceed!
Discussion Starter · #8 · (Edited)
Since i am a definite beginner with this,i will add more support to the board but for now it will do fine as is.I am just gonna layout the track .I am gonna go for winter/christmas theme.I have found some places that have the scenery trees covered with snow,and i am buying some stuff that fits perfectly with this kind of theme.What would i need to be put down besides the train tracks and scenery stuff?
Changed my track layout to use the 18 set pier bridge from bachmanns.Love the way the layout looks but train has problem going up,not sure how to try and solve that problem:(.
very easy - make it flat. but if you absolutely have to have elevation (i do as well :rolleyes:) don't climb as high and prepare for headaches. grades are not easy business
· Premium Member
Duke,
Looks like you're having fun with the white packing styrofoam. Go to it. Quick, easy, cheap tunnels.
Down the road, you might consider spending just a few dollars to buy some pink (or blue) insulation foam at Home Depot or Loews. It carves much more smoothly than the white stuff, without yielding all of the crumbling little white "beads" that packing foam is made from.
Nothin' wrong with a little creative recycling at this point, though!
Discussion Starter · #18 ·
got the rest of track today to finish the dog bone layout.Gonna try using cardboard to bluild up the track on the outsida to go up and over the end curve sectin nearest the garage door.Planning on having that connect to another smaller layout.
· Premium Member
"Ohh, exhalted King Gravitus ... I beseech thee to please be kind to Dukenukem. He dare doth venture ever so close to the Dreaded Edge. Nay ... sayeth not what you must think. For his intentions are most noble and pure. I implore you ... please grant him safe passage through The Land of Gravity so that he may live freely to see another glorius day in your kingdom."
Your most humbled subject,
1 - 20 of 21 Posts
