1 - 4 of 4 Posts
Finally had time to hook up my Powercab and in the instructions it says to plug the AC adapter into a switched socket. I'm assuming this is so I don't have to keep pulling the plug out of the wall socket.
I was thinking of mounting an AC toggle light switch on the front of my control panel connected to a plug under the panel so I can keep the adapter plugged in all the time. That way I can just use the toggle switch to power down the Powercab.
Good idea or bad?
Excellent idea. A power strip maybe easier and give you more places to plug in lighting transformers, DC controllers and anything else. One switch will cut power to the whole layout.
Good idea or bad?
Whatever works.
Personally, I have my MRC unit plugged into a power strip that is mounted under the layout.
Agree bigtime. The way to go is a switched power
strip. You'll be surprised at the number of units you'll
be plugging in over time.
One definite item to plug in; some sort of very visible
light that is on when the strip is on. That way you'll be
reminded to turn it off when you finish your session.
1 - 4 of 4 Posts
