I am seeing a dual post here.
Here are the diagrams. They are all very similar.
If you clean the drum connections it may help.
I merged all your threads. Do you have pictures?
Your fender has a reverse unit. The cylinder can be called a drum. When the drum rotates it will change the direction of the engine with a neutral state between directions. The fingers are the electrical contacts that touch the drum.
