1 - 20 of 283 Posts
Hello dear friends,
I want to introduce my freeware layout design program, called SCARM, which you can download and test from www.scarm.info/index_en.html. It has lightweight and intuitive user interface, 3D view, more than 25 track-system libraries and many other cool functions and features.
I will appreciate any comments concerning SCARM here or by email – scarm at scarm dot info.
I was not sure where to post this topic, so I do it here - please excuse me if I'm violating some of the forum rules.
Mixy,
from Bulgaria
Discussion Starter #2
New version 0.7.0 of SCARM
Hello again :)
The new version 0.7.0 of SCARM is released.
The most important new features are Print and Print preview mode for WYSIWYG layout printouts. Now SCARM holds more than 40 libraries with different scales and track systems.
Try it and say if you like it :)
Mixy,
from Bulgaria
@gunrunnerjohn: The main Lionel O library file is under development and will be available soon. As for point motors and other accessories – they will be included if possible (I will check them). For example – see electromagnetic point switches in Tillig BTTB library.
@kretinus: At the moment, all tolerances are set to 1mm max, because I need to verify various track systems geometry. Try some Atlas library and see it. In some of the next versions I will add an option in the Settings for user defined length and angle tolerances.
Mixy
from Bulgaria
Mixy,
I'll echo that that inability of other track layout softwar to include the projections of the control assembly on tradition Lionel switches like O22's is a major shortcoming. In planning a layout, the spacial impact of these control assemblies on track-to-track proximity is very significant. If any track layout software is simply blind to their existance, then the software's usefulness is limited.
That said, consider that a polite suggestion to add to your future development list.
Many thanks for offering info on your software here at the Forum.
Regards,
022 switches can be assembled with the motor on either side. The motor is about 4.5" long and 2" wide. The straight and curve part of the switch is exactly the same size as standard O31 track. Here are some pictures to illustrate that.
The first two pictures show the two configurations the 022 (and later variants of the tubular track O31 switches) can use. The third picture simply illustrates that the two paths on the switch are the same size as standard O31 track.
Let me know if you have any other questions.
Thank you, gunrunnerjohn :)
Pictures are clear and detailed. Now is midnight here so I am going to sleep, but tomorrow I will try to map the pics to track library file. Hope that Lionel O lib will be ready and tested till end of the week :)
Mixy,
from Bulgaria
Discussion Starter #13
OK, here is preliminary Lionel-O library file: http://www.scarm.info/temp/Lionel-O-tmp.zip. Download and extract it from archive, then copy .lib file into LIB folder of SCARM. Start the program and select Lionel-O from the libraries dropdown menu. At the moment, all tracks are labeled with their part numbers and only 14062 and 14063 turnouts have attachable accessories enabled. Select one of these turnouts with buttons from the selection panel to place on the plot – a dialog with possible accessories will appear. Select the switching motor (left or right) and press OK. This is the way how track accessories are realized in SCARM. Unfortunately, the Lionel catalog has no dimensions of these things at all, so I will ask you to tell me other possible switching motors dimensions and offsets in order to be able to put them in the library file, as marked on the picture. Offsets are horizontal and vertical dimensions from start of center rail to nearest corner of the motor. Try the lib and tell me – am I close or not? :)
Mixy
Mixy,
I would have to say that most of us in the U.S. are oblivious of the metric system is there any easy way to convert the track to SAE (Inches and feet) measurements?
Discussion Starter #17
Hi guys,
I checked the SCARM web site 2 minutes ago and it is up and working well. May be it is a temporary problem or something in the route. Check it again and tell me if the problem persists.
@NIMT.COM: Open "Tools" > "Settings" > "Measurement units" tab and select inches to be default dimension unit ;)
Mixy
Mixy,
Excellent, thank you
From a business point of view you might want to add in an US flag, English, with the dimensions defaulted to inches.
Oh and atlas code 100 track too! A lot of us still use it.
Still no joy for some reason. I can do a tracert to it, but when I ping it, I get timeouts. The odd thing is I got a couple of responses, then nothing.
I did get to it with a proxy server, but I can't download using that proxy. I'll wait to see if this gets sorted out.
1 - 20 of 283 Posts
