1 - 12 of 12 Posts
Hi all.
Running 2 wires for my bus, and feeding the feeders in with scotchlok suitcase connectors. Made a mistake and inserted the wrong feeder in one of them. Didnt realize until after I clamped down the metal piece. Was easily able to pull out the track feeder wire, but not the bus wire. Will leaving a scotchlok connector on a bus wire with no feeder attached be a problem?
My electrical skills are extremely low.
Yes I am using 16 gauge wire with 22 gauge kato feeder wire. Made sure to get connectors that fit each. Took a bit of pulling to get feeder out. End of it was stripped after coming out, so I'm sure the connection was ok.
Moderator Torpedo Emeritus
If I’m not mistaken, Scothlok are for 18-22 ga. And not for 16 ga..
The word scotchlok makes me shudder. I understand that it’s all indoors but those things fail constantly on equipment I work on so I delete them. I’ve used waytech connectors and deutch connectors to make jointed connections. More expensive but easier to troubleshoot and exponentially more reliable
Considering that the crimp was already squeezed tight and the wire nicked, I would leave it connected. Some people have used these for years, but I'm like Jscullans, they damage the wire and much better alternatives exist.
A guy I work with got fired for having those in his electrical kit. He used 1 and lost his job over it. Those things are strictly forbidden for me to use 😳
1 - 12 of 12 Posts
