1 - 20 of 26 Posts
Marklin Class P8 Tank Locomotive
My layout started with a simple barn structure that I scratchbuilt. I wanted a rustic European type barn to use for a small scene in my layout. After my research, I decided I would start with foam sheets to build the understructure support. Hope you enjoy.
Rectangle Font Parallel Handwriting Schematic
Rectangle Textile Wood Line Material property
Rectangle Font Material property Office supplies Flooring
After cutting the base shapes out, I glued them together using Titebond Glue…It just works ALL the time!
Wood Rectangle Office supplies Audio equipment Art
I used push pins to hold the ends together while the glue dried and also used corner pieces to reinforce the stability. You also use ¼” balsa to hold these corners or sturdier pink foam.
Rectangle Wood Grey Stairs Flooring
Rectangle Wood Tints and shades Writing implement Office supplies
The pieces where originally cut square so I used a foam scraper to have them match the roof line pitch. Blocks or jigs can be used to hold the structure while the glue dries.
Packing materials Shipping box Rectangle Carton Packaging and labeling
Shipping box Wood Rectangle Art Packing materials
With the main structure dry, I cut out the opens for doors and windows and fitted the structure with balsa for the door headers. The plan is to have sliding barn doors in the front an a single door on the side. More later. Thanks for viewing!
Wood Rectangle Gas Composite material Flooring
This material has the appearance of rough stucco. I think your barn would be an excellent candidate for half-timbering. Especially for that rustic look.
After this, I coated the entire structure with Woodland Scenics Flex Paste. This gives the walls a plaster look and can be cut away to reveal the brick work underneath.
Automotive tire Rectangle Wood Tread Automotive design
After the paste dries, the exteriors walls are painted and various cracks are applied using an Xacto. I painted this multiple time to get the right hue and weather look.
Brown Rectangle Beige Wood Flooring
In certain areas, I wanted exposed brick. I cut away openings and replace the areas with plaster brickwork.
Wood Metal Building material Chemical compound Soil
The Flex Paste gives a nice effect of pulled away plaster.
Wood Rectangle Trunk Artifact Art
After this, I was ready to work on the roof and some more details.
Building Rectangle Wood Art Bottle
The roof was my favorite. Although VERY tedious, I was vary happy with the result. I used 1/32" balsa cut down to strips. I then glued each strip, overlapping the previous one to "shingle" the roof. I then carefully took an Xacto and textured each row of shingles.
Brown Wood Rectangle Wood stain Flooring
Several coats of stain and paint were applied to give the feeling of aged wood shingles. I added a beam and pulley and also finished up the doorways and windows.
Window Wood House Building Rectangle
On the back side I added an overhang where I wanted to have a little workbench and I also added the sliding doors. All of this was balsa and styrene.
Building Wood Window Brick House
I add this to the layout and created the scene. Here is the final photo - Thanks for looking. Always willing to share and learn!
Wheel Tire Sky Plant Vehicle
Wonderful work. When I posted my suggestion I did not realize you had already completed your project.
Excellent! (y)
About how long did it take you to create that?
Discussion Starter · #7 ·
Thank you. I have been thinking about that type of building for sometime, but just need to figure it into my layout.
Thank You!!. I have about 60-80 hours into this one. Much of which was trial and error to get the right look.
So at $20 bucks an hour it is worth around $1200 to $1600 bucks.
At $15 per hour $900 to $1200 bucks.
You work cheap? At $7.50 per would be worth $450 to $600.
At $5 bucks per hour it is worth $300 $400. :geek:
Put it on your insurance list. :)
  • Like
Reactions: VilledeGrace
Discussion Starter · #11 ·
"Value is (sometimes) more expensive than price." —Toba Beta
Turned out very nice! I use quite a bit of Titebond III for my outside layout. It's waterproof and holds up well.
Never tried Woodland Scenics Flex Paste. I use Durham's Water Putty for that stucco look.
Discussion Starter · #18 ·
Thanks Maddog!. I do both additive and subtractive building. Additive, where I actually make the stones rather than carve the stones. Both methods have pluses and minuses. Thanks for looking.
Discussion Starter · #19 ·
That would look awesome in my Swiss village.
LOL, I just looked at your "About" I was AF as well worked with GLCM!!
I couldn't get a GLCM assignment. I didn't have enough TOS at the time. I would have loved to have gone to Belgium or Germany. That was my only chance to get out of the States.
Were you Minuteman or Titan?
1 - 20 of 26 Posts
