1 - 8 of 8 Posts
I have this same thread over on the OGR forum, so these first posts are going to be long to catch up on a few weeks worth of updates.
I intend to document my scratchbuilding of a New Haven rebuilt 36' double sheathed boxcar in this thread. After completing a few craftsman kits (Ambroid and Suncoast), I wanted to try scratchbuilding a prototype I had always wanted.
The New Haven did not own a single steel boxcar until 1941 - before then, the New Haven's boxcar fleet consisted primarily of 36' double sheathed cars built in the 1910s and rebuilt with new superstructures between 1926 and 1929. These rebuilds consisted of two groups - one with steel Dreadnaught ends and Youngstown doors, and one with steel reinforced wooden ends and wooden Camel doors. Over 12,000 cars were rebuilt. The full history of these cars is documented well in the New Haven Historical and Technical Association's 'Shoreliner' magazine, Volume 35 Issue 3, in an article written by John Nehrich and Chris Barkan. A diagram of these cars can also be found online here, under car numbers 160000-164999:
Alphabet Route - New York, New Haven, and Hartford
I want to model one of the cars with the steel Z-bar reinforced wood ends, but with a Youngstown door as some of these cars ended up in late 1930s. I purchased all the wood stock from Northeastern Scale Lumber. I calculated key dimensions from the diagram on the Alphabet Route site, as well as the Shoreliner article.
Like the Craftsman kits, I began by building a rectangular core from Northeastern's freight car floor, end sheet, and freight car inner roof pieces.
Cutting the floor and roof pieces to length:
Rectangle Handwriting Wood Font Hardwood
Rectangle Hood Netbook Office equipment Bumper
Building the frame with three pieces of end sheet, cut to the appropriate height:
Product Table Wood Yellow Tool
Bottle Wood Barware Table Space
Two pieces of the wood sheathing for the ends, cut to shape and ready to be attached. Before gluing them in place I coated the small ledges of the floor at the ends with Scalecoat sanding sealer and brushed with 00 steel wool. These ledges are on the outside of the car, and will be where the steel Z-bar bracing is applied.
Rectangle Wood Floor Wood stain Flooring
The end sheathing in was then attached, and 4 oz of weight were added to the interior of the car, centered over each end.
Furniture Shelf Wood Shelving Grey
The side sheathing (1/16" thick) was rough cut and added to the sides. Each side has three pieces. I sand the ends of each sheet to make the joints as inconspicuous as possible on the exterior.
Wood Sunglasses Rectangle Tool Gas
The side sheathing was then sanded flush to the top and bottom, matching the angle roof profile.
Wood Rectangle Bumper Floor Flooring
Second catch-up post to follow.
~Chris
Discussion Starter · #2 ·
Pieces representing metal sheets for the corner posts, top sheet, and bottom sheet were first applied using .020" thick wood strips. The pattern of the end beams were also added using the same strips, to keep the application surface for the end beams level. All trim and post pieces were coated with Scalecoat sanding sealer and cleaned with 00 steel wool before being applied.
Rectangle Wood Floor Flooring Composite material
End beams were made out of 1/16" angle pieces for the diagonals, and 3/32" Zee pieces for the verticals. Corner pieces for the polling pockets were added using more .020" strip wood.
Wood Automotive design Flooring Floor Rectangle
Wood Musical instrument Font Vehicle Folk instrument
I couldn't find any commercial polling pocket castings that I liked, so I decided to roll my own. I cut about 1/8" long pieces off a small wooden dowel, and glued them to the corner pieces - any shorter a length and the dowel began to disintegrate. After the glue was secure, I sanded them down to about 1/16" high. The rounded inside of the pocket was created by drilling a small pilot hole, and then using the tips of increasingly larger drill bits until I neared a size I liked. Sanding of the inside of the pocket was with the tip of a round Dremel polishing tool, and then a coat of sanding sealer was applied.
Musical instrument String instrument String instrument Wood Musical instrument accessory
That's all for now.
~Chris
Looks great! you also have all the right tools and patience to complete this project.
I have a Quality Craft Erie wood caboose kit I have been avoiding. I will no doubt learn from this thread and finally get to work on it…
Tom
Thanks Tom. I have an Ambroid D&H caboose somewhere in my queue - the good news is that Ambroid and Quality Craft made great, well designed kits, but I do have to admit the caboose is a little intimidating for me as well. Two Ambroid kits I completed earlier this year are below, an Erie horizontal rib hopper and a L&HR flanger.
Wheel Train Automotive tire Product Motor vehicle
Train Rolling stock Wood Vehicle Track
Train Rolling stock Vehicle Toy Track
I applied the roof sheets to the car last night (1/16" thick wood sheet), and let the glue set over night. Like the side sheathing, I purposefully cut it rough extending too far out from the sides. I then used a piece of 1/16" scrap sheet, taped to the side of the car, as a spacer and sanded the edge flat and parallel to the car side. I neglected to take a photo before doing this, so I staged the one below to show the concept.
Table Netbook Pen Desk Office supplies
After sanding the roof sheets, I applied the roof trim. On the sides is a scale 2x4, running the length of the car between the corner posts. The end trim was made of 1/16" square stock, sanded flush to the sheets with the sanding block. I had to notch out the Zee bars to fit the end trim.
Wood Automotive tire Rectangle Eyewear Automotive exterior
Musical instrument Light Blue String instrument Folk instrument
Wood Rectangle Audio equipment Hardwood Electronic device
Next up is some wood filler to cover the seam along the crest of the roof and in the trim pieces, and a coat of sanding sealer.
~Chris
Discussion Starter · #6 ·
The roof (sans roofwalk) has been completed.
I started by filling in the crest of the roof with wood filler, sanding smooth, and then coating in the usual sanding sealer and 00 steel wool. I cut a strip of paper the length of the roof and laid out the location of the roof panel seams on it, and used it as a guide to mark up the roof itself with a square edge.
Wood Scratch awl Hardwood Wood stain Flooring
Wood Flooring Table Hardwood Rectangle
The seams themselves were applied in two layers - a 1/8" wide .020" thick strip as the base, with a 1/16" wide .020" strip centered above it. The strips were cut to overhang the sides, and then sanded flush. The photo below shows one seam completed.
Wood Table Floor Flooring Wood stain
Each seam was then beveled from the roof edge in 1/8". The seams were then coated with sanding sealer.
Wood Rectangle Tablecloth Automotive design Flooring
I always find the roofwalks on boxcars to be easily marred during construction, so I do them last. I'll work on the underframe next instead.
~Chris
Discussion Starter · #7 ·
Underframe is in. Bolsters and centersill are pre-shaped parts. The sidesills and outer cross beams are scale 2x4s. The inner cross beams were made from some wood scrap I had lying around. I narrowed the bolster so the 2x4s fit over the sides, and sanded the angle on the top of the bolster flush. I also sanded the top of the bolster down even with the centersill, to lower the ride height with a pair of Weaver 3-rail trucks.
The white metal brake cylinders and brake levers are from Scale City Designs. The piping is from a roll of phos. bronze wire. I only represented the brake rigging that would be visible while the car was right-side up, and cut it back and kept it simple to avoid interfering with the 3-rail trucks again.
Wood Rectangle Floor Urban design Composite material
Wood Table Rectangle Line Gas
~Chris
1 - 8 of 8 Posts
