The first picture shows an original lens to the search light car,but often enough they look like the second.
So what to do. You can order replacements. Ebay had two for 6 bucks or you can improvise and go to the local hardware store.
I was looking for a nut for a snowblow when I stumbled onto these.
There I found two inserts.One is a 1 and 1/16th Hot water cap. The other is a nylon insert. The Hot cap was 2.80 and the nylon was 1.00.
The trial fitup is that they are loose. The nylon insert is a bit thick and needs to be trimmed. The Hot Water cap is better but both will need a wrap around the inside to thicken up the joint. A thin piece of rubber held in with electrical tape would do the trick. You don't want to use glue in case you break down and get the repro's.
The good thing about the nylon insert is you can add color lenses to it depending if you can find colored plastic. The hole is 7/8th of an inch.
