521 - 540 of 553 Posts
Discussion Starter #522
You'll notice some bunching and then taking out the slack. The trestle bridge is out of frame to the right. It has a pretty good hump (mistake), which makes for a lot of push-pull with the helper loco in the middle.
Discussion Starter #524
Thanks Michael.
Not as super slo-mo as yours, but not bad for a pair of Bachmanns... and there's four turnouts being traversed. :)
Discussion Starter #525
WS Windmill Kit
Broke out the WS windmill kit for the farm. The tower in the kit was scale ~ 15', which wasn't even as tall as the farmhouse, so it went in the scrap bin.
So, using 1/16" balsa sticks I started building a ~ 36' tall tower.
553590
553591
Horizontal braces cleaned up.
553592
Diagonal bracing started. 3 sides to go.
553593
Sine the windmill tower is a lot of glue, wait, glue, wait... I have a 1926 White flatbed and mine carts from Wiseman going at the same time.
553597
553598
Discussion Starter #528 (Edited)
"Vintage" Athearn Flat
554225
Stainless steel stakes. A new one for me.
554226
Kadee couplers and metal wheelsets added.
554227
A little aging on the deck... ready for the load.
554228
Wow, I've been looking back thru the thread and you've accomplished a ton! Very beautiful layout with an equally attractive season, the autumn colors really bring life to everything. Hopefully I can eventually create a layout half as decent.
Discussion Starter #539
Load o' Gravel
Finally got around to correcting the gravel load in the Virginian hopper. On the first try it settled more than planned and didn't look right. After I had it looking right I did the alcohol then 50/50 glue/water just like track ballast, which is what it is.
The car is an old Varney. The car body was in the shape you see in the pics when I got it, and you can see - in the 3rd pic especially - that one end of it is warped. Probably stored away in a hot attic for years. I was going to toss it, but then said, WTH, it's already "distressed". Put on Kadee couplers and trucks and it rolls and tracks fine.
554594
554595
554596
