601 - 615 of 615 Posts
Discussion Starter · #602 ·
I've been doing some winter camo on the 1/87 scale armor.
I found that troops used paint, dyes, white cloth and even salt to "winter camo" their tanks. With the idea in mind that different armor platoons would camo their vehicles in different ways, I tried different camo "styles" on the different types of vehicles.
Tank Self-propelled artillery Combat vehicle Wheel Vehicle
Plant Flower Green Nature Flowerpot
Self-propelled artillery Tank Flower Plant Combat vehicle
Plant Self-propelled artillery Automotive tire Wheel Tank
Tank Self-propelled artillery Vehicle Combat vehicle Automotive tire
Tank Self-propelled artillery Combat vehicle Motor vehicle Plant
Tank Self-propelled artillery Combat vehicle Vehicle Motor vehicle
Self-propelled artillery Tank Vehicle Combat vehicle Motor vehicle
Tank Self-propelled artillery Combat vehicle Vehicle Automotive tire
Plant Tire Automotive tire Road surface Motor vehicle
Discussion Starter · #603 · (Edited)
Finally got some decoders for the EMD F7 A/B set (Walthers Mainline).
The A unit is # 6714 which ran on AGS trackage and the B unit is # 6180 which ran on CNO&TP trackage (and they are actually lettered as such), so prototypically they most likely would not have been lashed up.
Southern's F7 A/B ratio was 6/3 on the AGS and 7/24 on the CNO&TP.
Discussion Starter · #608 ·
EMD F7 A/B set ...how do you like the details and drivetrain on their Mainline series F units?
Details are on par with earlier P2K stuff. Grab irons/rails are plastic, as with the earlier P2K, but they are not molded in. Doors don't open.
Drive train seems up to snuff, but the brass flywheels seem a bit "downsized".
I have a few P2K cab units, so maybe I'll do a side-by-side review. :coffee:
Discussion Starter · #612 ·
Before.
Wood Circuit component Engineering Pattern Composite material
A drop or two of each thinned way down with DA.
Liquid Purple Cosmetics Fluid Flooring
After first pass.
Circuit component Rectangle Font Wood Electronic component
After second pass with DA only.
Circuit component Electronic component Wood Audio equipment Gas
Soaking the balsa scraps in DA thinned black paint.
Rectangle Wood Road surface Font Metal
Completed load of rubble.
Wood Cuisine Dish Line Rectangle
After it all dries I'll glue the load in and hit it with matte clear from the rattle can.
About the road name...
Stumpy, have you ever seen a movie titled White Tiger?
If not, it’s a Russian-made movie about a T34 facing off against a Tiger. I’ve no clue if the sounds were accurate or not but the Tiger firing sounded “different.” Anyway, some great views, some interesting tactics, not overly gory, and an intriguing story.
