I use Fasttrack on my O Gauge layout. The layout is on 3/4" thick foam which is on 3/4" plywood. I was having problems with the track connections staying together when the heavy Lionel steam engine thundered down the track and hit the curve. I was continually having to push track sections back together as they would part enough to lose electrical contact. The holes in the Fasttrack are so small that only a nail might work, but I did not want to use nails. I found some skinny drywall screws about 1-1/2" long. I reamed out the holes in the Fasttrack to 9/64", put in the screws and the track is now secure. No more joint separation.
I have attached a picture of the screw.
