I have a number of Mendards boxcars and coal cars and I love them. They are not without their flaws though and one of the things that's been bothering me lately is the boxcar wobble. If you have never seen it this is what it is...
I have at least 20 boxcars and, while a good number of them are fine right out of the box, I've got about 6 of them that wobble like this. I also have another 4 that have trucks that are really stiff so the opposite problem. I decided to pull a few apart and take a look.
The first one I took apart was wobbling like the video. I pulled the c clips and measured the washer. This is the size I saw
Then I took one of the ones where the trucks were tight and measured that one
I pretty big difference in sizes there. Enough to cause the wobble for sure. I then took apart one that I would say is perfect and the size of the washer was the same at 1.25mm as the one that was too tight. In fact the vast majority of the washers on the cars as I've found are 1.25mm. I've only seen 2 cars so far with the smaller washers. I'm still working through my collection though.
What I've found is that there is some variance in the stem on the trucks and it's pretty important to match the washer to the truck. For some of the more wobbly ones I've found that a washer 1.30mm is perfect but for others the perfect size is 1.15mm or less sometimes. Never under 1mm though.
So with this knowledge I could go to the hardware store or find another way to resolve it. I took the other measurements for the washer which came to 12mm outside and 6mm inside and created my own washers using my 3D printer. I set a number of thicknesses from 1.0 - 1.3mm and printed out a bunch in pairs. I have attached the models that can be printed here and it costs pennies to print them
View attachment Menards_Boxcar_washers.zip
I fitted the northwestern boxcar in the video with the new washers and you can see how well it worked out. This car required the 1.3mm washer to resolve the wobble as it had the same wobble as the one in the video. It originally had the 1.25mm washers in it which in this case was too loose.
I'm ready to fix the rest now which is what I'll be doing tonight...
Attached are the 3d models that I printed. I printed them solid with 100% infill at 0.1mm resolution. Now my printer can't quite do 0.1mm resolution but it's pretty close. I took the results and rounded them into the correct baggie. I have lots of options for the perfect fit...:smilie_daumenpos:
