Do they make a section of track that can be turned on and off like for a siding application?
What kind of track?Do they make a section of track that can be turned on and off like for a siding application?
My toggle switch a HOKIE!?Using black tie 3 rail. What is the p/n for the insulators and does lionel have a switch for that. Would be nice if it was an integrated piece so its not hokie.
And HD has lamp cord for cheap if you order from their website and pickup at the store Sometimes online price is lower than the in-store price). Silver, white, brown and black colors make it easier to match your carpet/floor. They also have 16/2 wire if you feel the need for a heavier gauge (but I'm not sure Cole's switch works with the heavier gauge). You can probably get the the switch from HD in the same order.how about a lamp cord switch? You will need a a hot wire to the siding anyway. Should be no more than $2-3.
:appl:Well, a picture is worth a thousand words, I didn't think it needed any further description.![]()
Yeah but ...Well, a picture is worth a thousand words, I didn't think it needed any further description.![]()
Well, since the OP is using tubular track, John's pic is irrelevent!:cheeky4::cheeky4:Yeah but ...
What did you use to mount it hot glue or epoxy? Do you need silver solder or will regular 60/40 rosin core do? What size bit for the hole? Can you use a blue switch instead of red one? What diameter solder did you use? Can we bust your chops any more?
Help me out here guys![]()
Pretty sure all he said was 3 rail with black ties. Could be Realtrax.Well, since the OP is using tubular track, John's pic is irrelevent!:cheeky4::cheeky4:
