1 - 20 of 62 Posts
in order to break the routine a bit i started on new small diorama. the idea is to have some fun, gain skills and have perhaps a better location to photograph locos and rolling stock.
overview of first steps - the pink. since my original cliffs are not something i'm considering investing into WS rock molds this time...
future trestle.
· Premium Member
Looks like a nice display/photo backdrop.
I fiddled with the "pink stuff" recently, making some mountains for my HO layout. First time using the stuff. What I found worked well to best simulate the "natural roughness" of rock ledge was ...
I stuck a 50-grit, 1.5" diameter drum sander into the chuck of my drill. Then, with the thing spinning away, I whacked it into the foam, over and over. It gouged away, of course, but the resulting gouges all added up to a reasonably convincing series of ledges, crevices, etc. for the rock.
Anyone care to offer an opinion on how similar the pink stuff is to the standard, molded, white styrofoam blocks used in shipping things? I wanted to do some weathering and texture experiments w/o getting shredded foam all over the apartment. If they aren't chemically similar, though, I'm wasting my time.
I'm still curious about using acetone. I'm aware it tends to turn styrofoam into a puddle of goo; that said, there has to be something I can dilute it with to control the degree of dissolution.
The work you have done on your layout is classic granite formation---excellent work, too. Granite's dense and hard, retaining it's sharp edges for eons. Sandstone, though, it easily carved by wind and water, and softens into gentle, rounded curves. If I can get the foam's surface to flow just a bit, I might be able to reproduce the look.
Discussion Starter · #10 ·
piece of foam that i got was as-is . one of the blemishes was an area that was attempted to be glued with non foam friendly material. it looks nothing like sandstone to me. besides, foam is just a base. you cover it with plaster and spaclkilng for texture. it will be quite fragile without and not alst as long (accidents happen).
but give it a try if you must.
· Premium Member
Re: white packing foam vs. "Home Depot" pink insulation foam ...
The white packing stuff is typically made from compressed "pellets" or little foam balls. It doesn't cut very smoothly / consistently.
The Pink Stuff, however, is much more homegenous in nature, and can be cut/carved pretty uniformly.
· Premium Member
I used the Pink Stuff to carve a "granite" mountain / tunnel recently. I was really winging it, but it turned out OK. I think credit goes to a (dumb luck) choice of paint, applied via "bristle brush dab strokes" in 5 layers:
Layer 1 – full coverage
Benjamin Moore house paint (had some leftover!)
2099-50 CAFÉ MOCHA
Layer 2 – partial coverage
Apple Barrel acrylic paint (from Michael’s craft store)
20576 TOFFEE
Layer 3 – partial coverage
20526 COUNTRY GREY
Layer 4 – partial coverage
20575 SANDSTONE
Layer 5 – very light dabs of coverage
BLACK
Layers 2 thru 5 were all mixed about 50%/50% with water before applying.
I'm sure there's a gazillion other paint color choices, but these worked pretty well with me for a "granite" look.
1 - 20 of 62 Posts
