ok, so here is what i have
powerpack, verified working, but gets hot. its a starting point, you can use that untill you get something nicer. yours free
track. i have gobs of either steel or brass. i will give you enough to build a loop or two with some joiners. however it would be better if you buy a pack of joiners as well in your local hobby store. i also have couple crossings in brass. the 90 degree one can be used if you want to make figure 8 instead of the loop.
UP engine plus caboose. verified engine is running.
actually of the bunch that i recieved (see
http://www.modeltrainforum.com/showpost.php?p=13025&postcount=340) this is the only running engine.
15$ (with caboose) ?
its the older "pancake" motor bachmann so it is not smooth as nice flight-wheel equiped models but as i said it runs. the lightboard had a crack so i retraced it with regular wires just in case. will stay put. both lights are working
older bachmann cars. horn-hook couplers are truck mounted
10$ ?
some more cars. no boxes for these. horn-hook
3$ per car? (red caboose - yours free)
step up - newer bachmann. 8 wheel drive, runs like charm. equipped with knuckle couplers. boxcar has body mounted couplers (knuckles as well) and nicely weighted. both in like new condition. i can mount horn hook couplers there instead if you want.
20$ engine 5$ for the car?
walthers engine, also a great runner. i'm under impression it is another step up from bachman. found one just like that for 35 shipped on the ebay. how does 25$ sounds?
i'm also trying to sell 2 athrean BB models here
http://www.modeltrainforum.com/showthread.php?t=1966
i guess its time to lower the price to 25...
and i guess i'll shoot myself in a foot here:
http://cgi.ebay.com/Bachmann-CHALLE...wItemQQptZModel_RR_Trains?hash=item2a01bc06c3 although he seems to be missing couple items
