1 - 6 of 6 Posts
What is the secret to getting static grass to stand up. Mine seems to laydown more than be upright
probably either 1] don't have enough charge , or 2] too far away, should be 1 inch or less ..
i -assume- that you are using fairly thick glue mix, that holds the grass upright when the charge is taken away ?
Wvgca hit the nail on the head. It's generally an issue with not having enough charge or holding your applicator too far away. And if the glue isn't sticky enough, the fibers will fall over. I use full strength matte medium as an adhesive.
The result may vary a bit from one spot to another. As said earlier in the thread.. A good applicator and glue are the key factors.
1 - 6 of 6 Posts
