I’m looking for a timing circuit for my streets loop that will interrupt power to the center rail when a car pulls up to the stop sign and completes the circuit on the isolated outer rail. I didn’t even bother looking on-line because I figured someone here has probably already done something like this and knows a good product that I can simply hook up. I’m looking for something that has an adjustable delay of between 2 to 8 seconds and is rated for up to 22 VAC or VDC.
I’m also looking for what type of diode to use to lower voltage on faster cars so they all run at about the same speed. I did a very little bit of on-line research on this, but have no clue if I should use a 1N4001 or 1N4007 or something else entirely. Again, I figure there are folks here that know from experience exactly what to use.
Anyone have recommendations for timing circuit and diodes?
