1 - 6 of 6 Posts
G'day,
This is my first layout, 4x7'. After messing around for a few weeks I've finally got the track how I like it. I was going to do an up and over double loop, decided it would probably be too much for such a small layout. Anyway, just after some opinions or suggestions about my layout, and possibly some help.
I'd like to have a tunnel go through a hill at some point, I'm thinking the far end. Just after some ideas on what I could do with roads, and other scenery. I'm thinking I'd be better of doing a nice green sort of scene. Otherwise I'm a big fan of tundra/desert.
I did try planning on paper before I started, but found it didn't work so well for me. Worked much better working out a layout playing around with track on the board, not working so well now though.
Here's some pics.
YouTube - Building HO model rail layout
Trains that will be running are an Athearn Gas Turbine, and a couple of Australian T-classes. All freight.
Cheers!
Adam.
Get a copy of Anyrail. It beats paper and really does wonders for the planning stage of things.
Great start though. I would say a tunnel might be difficult due to the spacing between your tracks and the lack of space at the end of your board. Others might have some ideas on how to approach this. But you can easily mock up some stuff just using cardboard cut outs of the tunnel entry/exit etc.
Discussion Starter · #6 ·
You mean where the three are sitting? Yeah, the Gas Turbine would come off every time when going through there in reverse. Otherwise fine. Just finished replacing most of that section with some flex-track though.
1 - 6 of 6 Posts
