Should have added, It looks like, From what I have seen on TV.I agree with Big Ed...those were som straight "lines" he was cutting there! LOL
Actually, this video (or one like it I saw earlier) solved a minor mystery for me: in several of his excellent series of videos, Luke Towan uses a sprinkle of baking soda on the CA that secures items he glued together, and it always puzzled me why he did so. Now I know . . .I'll guess most everyone has seen one of these vids, but this one has a lot that could be applicable to model railroading.
Mmm, I think both reactions are chemical in nature (I think the plaster of paris setting up is just rehydrating baked gypsum, if memory serves), so I suspect that might not work. OTOH, one video I saw earlier successfully used cigarette ash as the "filler", so it might do just fine. Worth a try, I guess, especially if you've run out of old baking soda from your fridge!Seeing the baking soda is porous. I wonder if plaster would work?
Mmm, fair point, and I suppose it's also entirely possible that it's not really a chemical process at all, and the baking soda, cigarette ash or plaster are or would only be mechanically bonding to the CA, something like the pebble aggregate in a concrete mix. Any chemists amongst us?Cigarette ash is alkaline, so I suspect it's similar to baking soda in that regard.
Also, Cigarette ash, Harmful?Cigarette ash is alkaline, so I suspect it's similar to baking soda in that regard.
I thought the same thing: easier to change the plug. And…aren’t prongs of electrical plugs supposed to be metal to… you know… conduct electricity and provide grounding?Never saw it before. I can see using it for some applications. Pretty cool. As for the electeical outlet, yea it would have been easier to change the end.
This method works very well for many applications. Can even be drilled and tapped. Holds a good thread, have used it a few times.I'll guess most everyone has seen one of these vids, but this one has a lot that could be applicable to model railroading.
