raise that table!!
TJ ===
I was just getting ready to krap out and thought I would take one last look at the emails and came across yours.
You have an extremely good point, and I am not an engineer so it was by trial and error on some of the points. One thing that does enter into the whole thing is that the distance the main line moves is only half of the distance that the lifting lines do, so it was important to move the shackle as close to the motor as I could, thus leaving a longer distance on the lifting cables and so the angle does change, it is very little. The angles are relatively close, because I took the lines from the closest end of the table all the way to the back (where the other pair of lines came up) and then installed the pulley leading back to the shackle. This makes those lines quite a bit longer, but they still lift at the same rate. I didn't think about it, but I could have located those pulleys closer to the outside of the framework which everything mounts on, and that would have made the angles very similar. I didn't turn any of the pictures, but if that one would be rotated 1/4 turn so it would be looking up at the system, it would be easier to visualize. I was going to turn the computer sideways, but found that I could crank my neck enough to check it out
Anyway === good thinking and it was my first try at doing this, so I am open to any suggestions. But being a hard headed old man, I probably won't change it much, if any, as it does seem to work pretty good and I have had quite a few comments from those who have inspected it. For safety purpose, I thought about what I needed to do to be sure it may NOT fall while suspended, I used adjustable hooks to fasten between the eyes on the framework and the eyes on the layout and then released the pressure on the cables and allowed it all to hang from the hooks. Its kind of pain in the a== to get the ladder out to be able to set and remove the hooks, but I feel a bit more secure that way and it doesn't stretch out the steel cable that way.
I need to come up with a better idea for that part ?!?!?!?!?!?!
I forgot to include a picture of the overseer of this project ==== but not the BOSS!!
The plastic guard around the outside of the table frame has kept several errant locos from meeting the floor ===== especially when the grand kids came to try and run gramps train I had to have it happen once to make me realize that it could and I needed to do something to arrest that!! Picked them up from the local grocery store trash bin and then asked for others when they got thru with them. Also helps to be working there as a maintenance whatever and rather on my own terms and time!! Nice to be retired???? and then work on your own terms!!
