1 - 9 of 9 Posts
I acquired a Lionel 248 electric with, what appears to be, a Lionel 253 double reduction "Super Motor". It has new roller, wheels and gears. After a clean and lube the engine runs very smooth on the bench.
The loco would run sporadically on straights and stop on 0-27 curves. I traced the problem to the wheels being to close together. I spread them a bit and it runs fine. But the gears barley mesh when the wheels move out on that side.
I'm thinking a nylon washer as a shim on the non-geared side between the wheel and the axle bearing. I'd cut a slit in the washer to pop it on the axle. But it may be tricky getting it in there as space is very tight. And I do not want to remove the wheels.
Any ideas?
I have trimmed down bread loaf closures and used them for axle spacers. I got the tip from GRJ and he got it from someone else.
If you don't need bread right now, PM your address to me and I'll send you a few.
Worked like a charm :thumbsup::thumbsup:
Now to get them out to trim them down ...
I think it was T Man who mentioned the bread bag things here.
Odds are. I did remember a thread where wheel spacing was mentioned, but not enough to attempt a search.
We'll find out. When he hits the board, he'll see the calling him :)
I think he uses them for another fix too.
Can't beat the price.:D
Well the bread ties idea came from my better half , who read it online. The original use was tying electrical wires together. I collected a few. I do not believe I have used it as a wheel spacer.
So I can admit I am familiar with them but I may have suggested it. The search engine didn't help.
For wheel pressing I keep everything tight. I cannot recall ever needing more space. Maybe it was for an AF motor.
Discussion Starter · #9 ·
This was a Lionel pre-war double reduction motor. The wheels had virtually no side-to-side play (but not tight on the bearings). It ran sporadically on the track, stalling, no high speed operation, lurching, etc. Spreading the wheels a bit completely solved the problem resulting in consistent full speed and reliable low speed operation.
1 - 9 of 9 Posts
