1 - 5 of 5 Posts
"Im in the process of adding two of these to my small layout, ( I had Hornby ones mounted on top prior) and I've found one of the main layout frames is right underneath where I need to mount it duuuugh!!!! Any suggestions (polite) please.
Probably many different ways to configure a bellcrank or transfer mechanism to mount the Tortoise further away from the points. It would take a little imagination and trial-and-error engineering (are those contradictory?) 馃槄 But certainly someone on here has done it or seen it done...
Change the track pattern or move the support beam. It's your layout, you're allowed to do either one.
Yes, very true! Also, Circuitron even offers remote mounting as an option...
1 - 5 of 5 Posts
