1 - 17 of 17 Posts
Hello Again!
Another Noob question ;)
For cutting flex track can I use a regular side cutter?
I have quite a few of them...I also have a dremel I could use too but was wondering if a regular side cutter would be ok or is there something special about the model railroad ones?
Thanks!
Ron
When my Dremel cut-off wheel gets too small to get a good angle of attack, I use dikes to cut the track a bit longer than needed. Then I use the Dremel to make the final cut.
I use this method even with a new wheel.
I may buy a right angle attachment to cut track which is already glued in place.
Hello Again!
Thanks!
Ron
I use this it actually works well takes a little longer than the dremel but is less stuff flying around and I’ve had the dremel go rouge on me lol
the atlas track saw is pretty slow, but works for already laid down track ... normally needs very little file cleanup .. doesn't last forever, but the price is right ..:)
Never used one, most time there is something in the way of that long saw, which is why I never tried it. Things like; dwarf signal, track shanty, shrubbery, fingers:mad:
I know, "Don't knock it till you've tried it."
Always save the small wheels for the special jobs when you need a small slot. Use the fresh wheels for cutting.
the atlas track saw is pretty slow, but works for already laid down track ... normally needs very little file cleanup .. doesn't last forever, but the price is right ..<img src="http://www.modeltrainforum.com/images/smilies/smile.gif" border="0" alt="" title="Smile" class="inlineimg" />
Never used one, most time there is something in the way of that long saw, which is why I never tried it. Things like; dwarf signal, track shanty, shrubbery, fingers<img src="http://www.modeltrainforum.com/images/smilies/mad.gif" border="0" alt="" title="Mad" class="inlineimg" />
I’ve only used it to cut the new track before I put it down. Never tried it with it down already.
· Banned
All your troubles will be over if you ebay Xuron Rail Nippers [about $7].. They are great.
When you use it make sure the flat side of the jaws is facing the rail you're keeping; concave side faces the unwanted rail..Also, we cut the rail top to bottom (railhead to foot), not side to side. Nothing to plug in/recharge/change blades/tighten the chuck..And it clips the rail off very easily... Do it !!
One tip if you don't already know: If you are going to use 2 or more 3' pieces of flex to form a curve, lay them out straight (on the floor,say), add rail joiners, plug em together and solder the joint/s letting solder ooze into the joiner/s..Why ? Because when you go to bend them on the layout you wind up with a smooth curve. If you don't the flex will form a kink where they're joined and look crappy.. Also: Line up the 2-3 flexes so that the connective plastic between the ties is on the inside of the curve. This allows the outside of the curve to spread the ties out a tad more apart than the inside of the curve as the 1:1 scale does in tighter curves.. Good luck,
PS. Toots (WVgca), Above, is right. Get a little file and smooth the clipped rail ends just a bit before joining clipped rail ends.
One tip if you don't already know: If you are going to use 2 or more 3' pieces of flex to form a curve, lay them out straight (on the floor,say), add rail joiners, plug em together and solder the joint/s letting solder ooze into the joiner/s..Why ? Because when you go to bend them on the layout you wind up with a smooth curve. If you don't the flex will form a kink where they're joined and look crappy.. .
This is in part true, with some clarifying information.
If two 36" pieces of flex are soldered together in a straight line as described, you will need to lay (curve) the track from the center outwards. The outer rail gets shorter as you bend the curve, creating the staggered next track joint.
Now, if a third piece of flex was already soldered on with joiners in a straight line, the rails at that joint would not be able to slide in the ties due to the rail joiner hitting the tie clamps.
Now I've searched youtube for someone showing this whole process and did not find what I wanted, so..
I'm off to the layout to record a tutorial. Watch for a new thread in the HO section of the forum:smilie_daumenpos:
1 - 17 of 17 Posts
