Rotary cutter or multi-purpose tool with knife blade or knife
Home Depot, where else! I didn't think it existed either until I ran into a stack of it in Home Depot when I was looking for spline material I could use. I think its used for making neat curved walls without having to scribe the stuff. Its really flimsy, not sure how one would even get a single sheet into a truck. But then they have assorted scraps that are just perfect for my use. I think it would be possible to make beveled roadbed also, that would make a mess in the RR room where as cutting the stuff with a jig saw outside puts the mess out there also.
Lemonhawk;
If you want to cut drywall with less mess, as in cutting beveled roadbed, you could use a different tool, or possibly a different blade in your "jig" (sabre?) saw.
A "rotary cutter" is used by seamstresses to cut fabric. It's sort of a cross between a pizza cutter and a surgical scalpel. It has the same handle and round cutting blade configuration as a pizza cutter, but is about a hundred times sharper! This tool will slice neatly through anything including you, so be careful using it.
Both sabre saws and "multi-purpose" electric vibrating tools can accept knife blades, which generate a lot less dust than even fine-tooth, metal-cutting blades made for the same tools. It's also possible to hold a shop vac nozzle right next to these tools as they cut.
Finally there is the common utility knife. Razor sharp, with a strong handle, and it cuts through drywall very well.
regards;
