Yes, I have
Just looked at a YouTube video where entire track and road bed were being spray painted with RustOleum Camouflage (Earth Brown).
After paint dryed, the tops of the rails were sanded with #2 sandpaper.
Anyone have any experience using this method?
jaydv;
I have done this, though I don't paint the roadbed. Perhaps the video was done by someone using a "roadbed track" like Kato unitrack, or Bachmann EZ-Track?
I make my own roadbed, and sub-roadbed, from Luan plywood. I do paint it, but with latex house paint and a paintbrush, not spray paint.
If you decide to try the spray paint method, be careful not to get too much paint on the track. That's all-too-easy to do, since spray cans put out a whole lot of paint in a big hurry! Keep the can at least 18" away from the track, and constantly moving. It's best to use several very light partial coats, rather than trying for full coverage in one coat. The spray can will cover in one coat, but in doing so, it will put enough paint on the track to gum up the rails. Easy does it!
A better way of painting track is to use an airbrush instead of a spray can. The amount of paint can be controlled much better, and you can safely spray from much closer. I paint the entire track, rails and ties, with an airbrush first. Then I paint the sides of the rails a different color than the ties, using a small artist's brush. The photo shows one of my scratch-built turnouts that was painted this way.
I disagree about the use of sandpaper to remove paint. I have used fine grit sandpaper and had no problem with the track. If you prefer to not use sandpaper, a paper towel dampened with a little alcohol should remove the paint. The "wipe the rails with a piece of wood, while the paint is still wet" method works too, but you have to be quick, since spray paint dries pretty fast.
good luck, have fun!
