Track question 15" radius
1 reading
5.1K views 9 replies 10 participants last post by  tkruger
#1 ·
I notice a lot of engines shoe minimum radius in their description 18/22 etc. I have a few 15' radius bends on my layout does that mean I can't run these? Why have 15" radius track then?
#6 ·
Back when we built our first layout space was an issue and we tried 15's, The Athearn SD 40's and longer rolling stock would jump the track or bind in the curve on the 15's. Most shorter locos and stock did OK
Now 3 builds later there's 22's and up with only 3 18's in the whole layout.
IMHO more realistic and smoother traversing of curves.
#7 ·
Check your coupler clearance and truck travel, most times it is that not being able to move far enough that causes problems. Ladders and suchlike can get in the way. My DD40 AX has been 'chopped' and can take 15"s! Steamers are more snicky, they mostly will not take anything under 24" but you never know, my BLI 2-10-2 takes 15's no problem right out of the box, the Bachman 4-8-4 is another story, it won't do anything less than 24"! Rolling stock is a crap shoot, some will go anywhere and others will ONLY go on WIDE turns. Kinda a pain but each individual type of loco and roller have different needs for smooth rolling operations. Some "tweaking" of each piece of stock is sometimes needed.
#9 ·
The only way to know for sure is to test it. Make sure you test groups of cars coupled together, as it's often the car bodies or trucks that don't have enough clearance.
#10 ·
I have found that Athearn Blue Box 4 axle diesels and 40ft rolling stock from that era will normally work if not run to fast. Anything bigger has issues. I have also found that most newer locomotives have more issues with the tighter curves than the older ones did.
I have an 18r turn and a 17r turn heading into my turntable. Not a big issue since the table can only handle locos 9 inches or less. All other curves are 22 or greater on mine.
